DO radiation exterior semi-transparent wall
Old   October 24, 2012, 09:59
Default DO radiation exterior semi-transparent wall
wawa
wawa is on a distinguished road
I'm trying to simulate a simple window using DO-radiation. Both sides of the window are defined as semi-transparent, for the radiation to pass through the window. Absorption and scattering coefficients are used.
My issue is that although all surfaces are adiabatic, the temperature of the window should increase due to the incoming radiation. But, the temperature decreases. This is because the total radiation heat transfer from the side where radiation exits the window, is higher than the incoming radiation.
How should I define the window side opposing the incoming radiation ?
Thanks...
wawa is offline   Reply With Quote
Radiation to wall Pekka OpenFOAM 2 May 17, 2012 05:28
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
