DEFINE_SOURCE error?
Old   September 19, 2012, 17:26
Default DEFINE_SOURCE error?
twray is on a distinguished road
I'm trying to implement the RAS turbulence model and am having a problem with the R transport equation. If I hard code a value for R and turn the equation off I get reasonable results and trends for all my variables. When I turn the R equation on the solution diverges or I get non physical results. Based on trial and error, I think the problem is in my DEFINE_SOURCE.
DEFINE_SOURCE(r_source, c, t, dS, eqn)
real source;
source = C_UDMI(c,t,C1)*C_R(c,t)*sqrt(C_UDMI(c,t,P)*C_UDSI( c,t,RTilda))-C_UDMI(c,t,C2)*C_R(c,t)*SQR(C_UDSI_G(c,t,RTilda)[0]+C_UDSI_G(c,t,RTilda)[1]);
dS[eqn] = 0.0;
return source;
RTilda is a UDS so that I can use C_UDSI_G to get the gradient easily. Is my use of C_UDSI_G correct? Is there some other error here?
twray is offline   Reply With Quote
define_source
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user defined function cfduser CFX 0 April 29, 2006 11:58
