Macros - Time dependent
Old   September 11, 2012, 05:47
Default Macros - Time dependent
saisanthoshm88 is on a distinguished road
Could some one please explain the difference between the solver macros CURRENT_TIME and CURRENT_TIMESTEP in Fluent.
I'd appreciate an explanation with a short example
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   September 11, 2012, 06:35
Amir's Avatar
Amir
Amir is on a distinguished road
CURRENT_TIME is the current physical time and CURRENT_TIMESTEP is the current numerical used time step. (In some algorithms, the floating time step may use)
e.g., for a case with fixed time step of 1 sec, after 10 time step we have:
CURRENT_TIME=10 sec
CURRENT_TIMESTEP=1 sec
Bests,
Amir
Amir is offline   Reply With Quote
Old   September 11, 2012, 07:50
Thanks for the reply Amir. I've a question on writing a udf that involves an interpolation
For instance i have the following case where the inlet pressure varies with times as follows:
Time [sec] - 0 0.2 0.3
Pressure [Pa] - 0 10 0
so the udf should now interpolate for the values of pressure in the intervals [0,0.2] and [0.2,0.3] in this case.
Here it is only a few points so it may be easier to just extract the interpolation functions easily and frame the udf but is there a better way of doing this when the data is much.
Best regards,
Santhosh.
Old   September 11, 2012, 09:10
Amir's Avatar
Amir
yes, there is. You can use a profile instead of UDF. (refer to the manual-> transient profiles)
Bests,
Amir
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
time dependent curve faiz rauf FLUENT 0 August 31, 2004 14:02
Time Dependent Solutions. rakib FLUENT 2 June 28, 2000 08:39
