heat and mass Udf
Old   September 6, 2012, 11:36
Default heat and mass Udf
thuhangbk48 is on a distinguished road
Hi all,
Now, I am studying to improve heat and mass transfer between multicomponent particle and gas phase (spray drying process). As you know, we have some laws (1 for heating to T_ vapor, 2 for evaporation, 3 for boiling, 6 for heating).
I do not know if I combine the DPM_Heat_mass, I must not use above laws or can I use this combined function instead of 2nd law?
Besides, do you know why I use only DPM_heat_mass as udf manual (2.5) of version 12 and inactive all of custom laws, I found that droplet evaporate only when the Temperature reach T _ boiling (100oC)
Thank all
thuhangbk48 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 03:07
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
