coupled motion using six dof udf but with restraints
Old   September 4, 2012, 16:51
Default coupled motion using six dof udf but with restraints
omer
fluentuser2003 is on a distinguished road
hi, i want to solve the trajectory of an object in air using six dof and dynamic meshing, however the problem is that is this particular problem , the object has a fixed constant axial velocity, rest its free to move in 5 degrees of freedom.
how can we restrict the object in 1 degree ie the axial velocity to a fixed value and use six dof to solve for the trajectory in other five degrees
i hav used a basic six dof udf , specifying mass and moment of inertia . but n unable to set axial velocity to a constant through out
thanks in anticipation
fluentuser2003 is offline   Reply With Quote
dynamic meshing, prescribed motion, six dof udf
Motion UDF udf_users_newbee Fluent UDF and Scheme Programming 4 May 31, 2013 06:04
Cheating to Get More Than 5 Force Inputs in Coupled Motion GMO Stromboli FLOW-3D 0 July 6, 2012 01:12
UDF for non sinusoidal or varying amplitude motion with respect to time lalit kumar FLUENT 1 November 13, 2010 17:58
UDF for Airfoil in Circular motion (2D) sohail_27 Fluent UDF and Scheme Programming 4 October 4, 2010 14:36
heat flow UDF on coupled surface (wall-shadow wall) Friedmann Fluent UDF and Scheme Programming 0 August 5, 2010 11:25
