August 29, 2012, 09:50 |
a problem of property UDF!I need help
wen han
Rep Power: 14 |
Hi,everyone! Nice to meet you! I have got a problem about material properties.I have writen a UDF for thermal conduction and viscosity,and i can compile and load the udf,there is no error,but when i edit the property in the material panel,i choose the option "user-defined",and i can see the udf,the problem is that i can't choose it.For check the problem,I write a simple code instead my code,but it has the same problem,I don't know whether my software has problem. my simple code is below: #include "udf.h" DEFINE_PROPERTY(tc,c,t) { return 10.0; } the same problem i put in the image. Thanks for everyone,i need your help eagerly,Waiting for reply. Last edited by hw0076; August 29, 2012 at 09:55. Reason: picture error |
August 29, 2012, 10:06 |
wen han
Rep Power: 14 |
i don't know how to upload picture,my picture all can't be displayed.
August 29, 2012, 22:28 |
wen han
Rep Power: 14 |
Additional,there is another error I think maybe caused by same reason。That is when I compiled and loaded the simple test function above,I choose “define”-"materials"-"user-defined database"-input "1" for database name-ok-new-input "1" for material name-types choose "fluid"-choose one of the available properties,for example,viscosity-then choose viscosity on the right-edit-choose the available properties for "user-defined"-edit properties choose "user-defined"-edit,then,I can't open the "edit" panel,and I got a error notice "Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()". That's why? I have been confused for days,I really want the solution. Thanks. |
material properties, udf and programming |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 04:28 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
