August 27, 2012, 15:35 |
Problem writing data file
Fer Villa
Rep Power: 14 |
Hello all,
I'm trying write the values of a variable through of an UDF. I'm run the case on a Cluster with linux platform. My UDF is: real Utb; real Xs; FILE *fp; DEFINE_EXECUTE_AT_END(velocity_integral) { Domain *domain; Thread *thread; real sum_vel=0.; real vol_gas=0.; real vol_tot=0.; real vel_u, axis; real Xinit = 0.05; real X[ND_ND]; real flow_time = CURRENT_TIME; cell_t cell; fp = fopen("vol_gas.txt","w"); domain = Get_Domain(1); if (N_TIME<=1.) Xs = Xinit; else Xs = Xinit + Utb*flow_time; thread_loop_c(thread,domain) { begin_c_loop(cell,thread) { vel_u = C_U(cell,thread); vol_tot += C_VOLUME(cell,thread); C_CENTROID(X,cell,thread); if(X[0]>=Xs && vel_u>=0.) { axis=X[0]; sum_vel += C_UDSI(cell,thread,0)*C_U(cell,thread)*C_UDSI(cell ,thread,3); vol_gas += C_UDSI(cell,thread,0)*C_UDSI(cell,thread,3); } fprintf(fp,"vg: %g X: %g um: %g\n", vol_gas, axis, sum_vel); } end_c_loop(cell,thread_l) fclose(fp); } Utb = sum_vel/vol_gas; printf("Volume total: %g\n", vol_tot); printf("Volume gas: %g\n", vol_gas); printf("volume integral: %g\n", sum_vel); printf("Velocity of the Taylor bubble: %g\n", Utb); printf("Distance step: %g\n", Xs); } When I load the UDF compiled, the message is: The UDF library is not compiled for parallel use on the current platform (lnam64). I think that the error is in the printf, fprintf, fopen and fclose commands, due to when I compile and then load the UDF without this commands, it works well. Moreover, when I run the case with this UDF on the Windows 64 bit platform, also works well. Anyone know what could be the problem?, when I run the case on Linux platform (cluster). Thanks!!! |
August 29, 2012, 04:55 |
Anton Khokhlov
Rep Power: 14 |
As it is clearly specified in UDF manual you should write to file only from host. You will face the same problem running this code on Windows cluster (or even simply in parallel).
August 29, 2012, 14:47 |
Fer Villa
Rep Power: 14 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
