surface tension gradient using UDF; surface tension gradient as function of temperatu
Old   June 21, 2012, 05:48
Default surface tension gradient using UDF; surface tension gradient as function of temperatu
sundar
marimuthusundar is on a distinguished road
Hi ,
I am modelling a melting problem in which I need to input (wall Marangoni stress) surface tension gradient as a function of temperature. Can any one tell how to access the wall surface tension gradient using UDF. Or is there is any other method to specify it as a function of temperature.
Thanks
Sundar
marimuthusundar is offline   Reply With Quote
marangoni stress, surface tension gradient, udf
surface tension as function of normal gradient tom FLUENT 2 September 7, 2016 04:48
temperature gradient for use in surface monitor Catherine FLUENT 1 August 24, 2012 10:10
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
UDF for surface tension gradient kiran FLUENT 2 July 15, 2003 13:00
