Save variable in DEFINE_EXECUTE_AT_END
Old   June 18, 2012, 13:10
Default Save variable in DEFINE_EXECUTE_AT_END
Tim Sønderby
tim.sonderby is on a distinguished road
Send a message via Skype™ to tim.sonderby
HI,
I have a problem to store the CURRENT_TIME so that I can be used in the workbench as a parameter.
I have tried to use C_UDMI(c,t,0) but that does not work (yes I have allocated memory), but that juse returns a FATAL_Vialation.
everything works except for the storage of the time into a variable that can be acceded from the workbench:
UDF to calculate the variance on concentration. This can be used
for dertermination of the mixing time.
Define the limit for the variance that defines the mixing time.
Make sure that the tracer is the first material in mixture.
Auther: Tim Soenderby
Created: 16 June 2012
Modified: 16 June 2012
#include "udf.h"
#define TAU_LIMIT 1e-8
real num_cells;
real avg_concentration;
real volume;
real TAU;
real mix_time;
DEFINE_EXECUTE_AT_END(store_mixing_time)
/* declare domain pointer since it is not passed as an argument to the DEFINE macro */
Domain *d;
Thread *t;
cell_t c;
/* Get the domain 1 (Mixture) */
d = Get_Domain(1);
num_cells = 0.;
volume = 0.;
avg_concentration =0.;
TAU = 0.;
/* Loop over all cell threads in the domain */
thread_loop_c(t,d)
begin_c_loop(c,t)
avg_concentration += C_YI(c,t,0)*C_VOLUME(c,t);
volume += C_VOLUME(c,t);
num_cells += 1;
end_c_loop(c,t)
avg_concentration = avg_concentration/volume;
thread_loop_c(t,d)
begin_c_loop(c,t)
TAU += (C_YI(c,t,0)-avg_concentration)*(C_YI(c,t,0)-avg_concentration);
end_c_loop(c,t)
/*calculating the variance*/
TAU = 1/(num_cells-1)*TAU;
if (mix_time == 0.)
Message("**************** CHECKING IF MIXING TIME IS REACHED ***************\n");
if (( TAU < TAU_LIMIT) && (TAU > 0))
mix_time = CURRENT_TIME; /*source of error*/
C_UDMI(c,t,0) = mix_time;
Message("Mixing time is reached, and is: %g\n", mix_time);
Message("Number of cellss are: %g\n", num_cells);
Message("volume is: %g\n", volume);
Message("avg_cons is: %g\n", avg_concentration);
Message("TAU is: %g\n", TAU);
tim.sonderby is offline   Reply With Quote
Old   June 19, 2012, 06:04
Tim Sønderby
Okay I found a solution.
C_UDMI has to be in a loop, otherwise it crashes.
Old   November 23, 2012, 10:22
Kanarya is on a distinguished road
I would like to save the mass flow rate only at outlet. is it possible with DEFINE_EXECUTE_AT_END?
thanks in advance!!!
Kanarya is offline   Reply With Quote
memory, _at_end
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 22:49
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
