Compilation error in UDF for gas-solid fluidized bed
Old   June 9, 2012, 21:05
Default Compilation error in UDF for gas-solid fluidized bed
Amir Hossein Ahmadi Motlagh
ahmadimo is on a distinguished road
Hi all,
I am simulating a 2D gas-solid fluidized bed using eulerian/eulerian plus granular flow theory. I have two user-defined memory variables (C_UDMI(0) and C_UDMI(1)) and want to calculate C_UDMI(1) for each cell in my domain using C_UDMI(0) of adjacent cells.
I need to loop over all faces of a cell and find out if the solid mass flux is going into the cell or outside of it. If going into, then I will use the value of C_UDMI(0) of the adjacent cell to find out the C_UDMI(1) value. For this purpose I have written the following UDF:
DEFINE_ON_DEMAND(on_demand_calc)
     Domain *d;
     Thread *mix, *par_t, *tf,  *t1;
     Thread **pt;
     cell_t c, c1;
     int n, m;
     d = Get_Domain(1);
     m = 0;
   mp_thread_loop_c (mix,d,pt)
          par_t=pt[1];      /* solid phase */
          begin_c_loop(c,par_t)
               c_face_loop(c, par_t, n)
                  tf = C_FACE_THREAD(c, par_t, n);
                    c1 = F_C1(tf, par_t);
                    t1 = F_C1_THREAD(tf, par_t);
                    if(F_FLUX(tf, par_t)<0)
                    C_UDMI(c, par_t, 1) += C_UDMI(c1, t1, 0);
                    m += 1;
               if(m!=0)
               C_UDMI(c, mix, 1) /= m;
               m = 0;
               else
                    C_UDMI(c, mix, 1) = -1;
          end_c_loop(c,par_t)
When I try to interpret this UDF I get an error that "non-integer subscript expression: unsigned char." on the following line:
I would appreciate if you could check the issue and advice if I am going the right way or I have errors in the way of accessing data in my UDF.
Thanks
Amir
ahmadimo is offline   Reply With Quote
Old   June 14, 2012, 04:32
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
http://www.cfd-online.com/Forums/flu...face_loop.html
laurentb is offline   Reply With Quote
gas solid fluidizd bed with cfx mohamad CFX 5 July 28, 2010 16:15
how to define static bed height for fluidized bed mohamad CFX 6 July 28, 2010 15:46
gas solid fluidized bed with ansys cfx mohamad CFX 0 November 21, 2007 18:55
particle volume fraction in fluidized bed gopinath bandari CFX 0 October 6, 2006 04:26
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
