multiphase udf
Old   June 7, 2012, 01:15
Post multiphase udf
ak2009 is on a distinguished road
Hi....
I am writing udf for multiphase flow to access the phase level data (primary phase).
I tried two ways to define the problem. Giving below both the udfs
I'st udf
#include "udf.h"
DEFINE_EXECUTE_AT_END (calculate_water_flow_rate)
int phase_domain_index = 0;
Domain *subdomain;
real total_flow_rate=0;
face_t f;
subdomain = Get_Domain(2);
int ID = 6;
Thread *thread = Lookup_Thread(subdomain,ID);
thread_loop_f(thread,subdomain)
begin_f_loop_all(f,thread)
total_flow_rate += F_FLUX(f,thread);
end_f_loop_all(f,thread)
printf("flow rate of water at outlet: %g/n", total_flow_rate);
In here, I have to access the phase level info (for primary phase, water) at outlet (ID - 6). So used the lookup_thread utility to find the approrpiate phase level thread.
Then I intend to estimate total flow rate of water going out from outlet faces. So looped over all the faces in the outlet thread.
The udf compiles . It gives some value which does not match with that calculated by fluent in the outlet boundary.
Is there any method by which I can read the outlet flowrate directly.
2nd UDF is....
#include "udf.h"
Domain *mixture_domain;
Domain *subdomain;
face_t f;
mixture_domain = Get_Domain(1);
int ID = 6;
Thread *mixture_thread = Lookup_Thread(mixture_domain,ID);
Thread *subthread =
THREAD_SUB_THREAD(mixture_thread,phase_domain_inde x);
thread_loop_f(subthread,subdomain)
begin_f_loop_all(f,subthread)
total_flow_rate += F_FLUX(f,subthread);
end_f_loop_all(f,subthread)
In here, tried to dig the same info using THREAD_SUB_THREAD loop. First used the lookup thread utility to find out the mixture thread at outlet (ID - 6). Then using thread sub thread loop, accessed the phase level thread for primary pahse.
In both cases, I get some value of otlet water flow. I am not sure if either of the approaches is adequate for the case.
Need inputs about udfs....
Thanks
ak2009 is offline   Reply With Quote
UDF for coal combustion in multiphase flow niisha24 Fluent UDF and Scheme Programming 13 September 19, 2022 05:01
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
Multiphase udf ak2009 Main CFD Forum 0 June 5, 2012 16:52
Multiphase Mass transfer UDF issue therandomestname FLUENT 0 April 21, 2011 15:51
UDF for multiphase flow ROOZBEH FLUENT 3 April 7, 2004 18:54
