need help for parallelize a serial UDF
Old   May 22, 2012, 09:01
Question need help for parallelize a serial UDF
Sandeep
sandeep_tu is on a distinguished road
I'm trig to run a UDF that should do the followings:
1-reading some values from a text file in HOST
2-transfering these values to the NODES
3-seting as the boundary condition in NODES
the codes is this.
DEFINE_PROFILE (Temperature_profile,t,j)
int node_zero = 0;
int node_host = 999999;
int node_one = 1;
int node_serial = 1000000;
int zone_ID;
int names[48];
int ID[48];
double temp[48];
double emiss[48];
double tempp;
int i,ii,iii,pe;
ii=0;
iii=329;
pe=0;
for (i=0; i<48; i++)
names[i]=20;
ID[i]=0;
temp[i]=0;
emiss[i]=0;
#if !RP_NODE
FILE *fi=fopen("input.txt","r");
if(fi==NULL)
return 1;
#endif
#if RP_HOST
fscanf(fi, "%d",&names[i]);
fscanf(fi, "%d",&ID[i]);
fscanf(fi, "%lf",&temp[i]);
fscanf(fi, "%lf",&emiss[i]);
#endif
I don't know how to make the communication between host and nodes,
I also used host_to_nodes but it didn't work
#if !RP_HOST
zone_ID=THREAD_ID(t);
face_t f;
for(i=0;i<48;i++)
ii=5;
if(zone_ID==ID[i])
ii=i;
tempp=temp[i];
I don't know whether it's right to use "compute_node_loop_not_zero (pe)"
here!!!!!
begin_f_loop(f,t)
if PRINCIPAL_FACE_P(f,t)
F_PROFILE(f,t,j)=temp[ii]
end_f_loop(f,t)
#endif
#if !RP_NODE
fclose(fi);
#endif
sandeep_tu is offline   Reply With Quote
UDF Parallel error (Is operating only in the serial.) startup0820 Fluent UDF and Scheme Programming 0 March 7, 2012 08:26
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Can any one suggest How to Parallelize Serial UDF sri31049 Fluent UDF and Scheme Programming 0 September 9, 2010 08:10
parallelization of serial Fluent UDF for surface reaction sri31049 FLUENT 0 September 8, 2010 15:15
parapllelizing a serial udf mahi FLUENT 1 November 13, 2008 09:32
