Need Help!!! parse error UDF
Old   May 11, 2012, 17:40
Default Need Help!!! parse error UDF
Fer Villa
fevi84 is on a distinguished road
I'm using the VOF model in 3D, with water (ID=2) as primary phase and air (ID=3) as secondary phase. I made a UDF for initializing volume fraction of phase air with the Taylor bubble form (a cylinder with a half sphere at the top).
#include "udf.h"
#define Xc 0.0
#define Yc 0.0
#define Zc 0.045
#define r 0.0085
DEFINE_INIT(gas_fraction_axis,mixture_domain)
int phase_domain_index;
cell_t c;
Thread *ct;
Domain *sd;
real X[ND_ND];
sub_domain_loop(sd,mixture_domain,phase_domain_ind ex)
if (DOMAIN_ID(sd) == 3)
thread_loop_c(ct,sd)
begin_c_loop_all (c,ct)
C_CENTROID(X,c,ct);
line 25 if (X[2]<=Zc && sqrt(ND_SUM(pow(X[0]-Xc,2),pow(X[1]-Yc,2)))<r)
C_VOF(c,ct)=1.;
line 27 else if (X[2]<=Zc && sqrt(ND_SUM(pow(X[0]-Xc,2),pow(X[1]-Yc,2),pow(X[2]-Zc,2)))>r)
C_VOF(c,ct)=1.;
line 29 else
C_VOF(c,ct)=0.0;
end_c_loop_all (c,ct)
When i interpret my UDF file, it says parse error in line 25, line 27 and line 29.
This UDF is similar to that appear in UDF manual FLUENT 12 page 333, but I don't know why it fails.
Someone knows the problem?
Thank you
fevi84 is offline   Reply With Quote
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 11:26
parse error in transient udf spring FLUENT 1 July 6, 2010 07:26
Parse Error Message While interpreting UDF in FLUENT dhimans Fluent UDF and Scheme Programming 1 July 10, 2009 07:29
UDF parse error alemenchaca FLUENT 0 July 1, 2009 20:45
PARSE ERROR Message when interpreting UDF in FLUENT dhimans FLUENT 0 May 24, 2009 12:40
