May 8, 2012, 18:29 |
Velocity profile UDF
Rep Power: 15 |
I'm trying to create a tranverse velocity profile UDF to use it as velocity inlet boundary condition to simulate flow in a water tank. The UDF is as follows: ######################################## DEFINE_PROFILE(Velocity_Profile_Z, thread, index) { real x[ND_ND]; /* this will hold the position vector */ real z; face_t f; begin_f_loop(f, thread) /* loops over all faces in the thread passed in the DEFINE macro argument */ { F_CENTROID(x,f,thread); z = x[1]; if (z < 0) z = z*(-1); else F_PROFILE(f, thread, index) = 1*pow((z/(12.8)),0.142857); } end_f_loop(f, thread) } ############################################ When I run the simulation, once it converges I plot a XY Plot, see attached figure . In my case the Z-axis represents the abscissa and the velocity magnitude the ordinate. The plot shows that even do the function represents the desire velocity profile, there is almost none velocity magnitude variation!!! Does anyone have an idea of why is that happening?? Thanks in advance. [/URL] |
May 9, 2012, 04:11 |
Daniel Tanner
Rep Power: 18 |
You have set z = x[1]. This is the y direction on your mesh, is that correct? The x vector is given by: (x[0], x[1], x[2]) which is equivalent to (x,y,z).
Worth checking this. |
May 10, 2012, 13:03 |
Rep Power: 15 |
Thanks Daniel!!
That was the problem!!!!! |
UDF problems - velocity profile | Oli | Fluent UDF and Scheme Programming | 6 | October 24, 2016 10:38 |
Logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 0 | April 23, 2009 19:09 |
How to specify the Velocity profile (eqn) by UDF | Anant | FLUENT | 1 | February 27, 2008 14:54 |
Multi step transient UDF velocity profile problem | William177 | FLUENT | 1 | February 3, 2008 06:47 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 12:14 |
