velocity inlet using udf
Old   May 5, 2012, 13:22
Wink velocity inlet using udf
hilla tor
hillator is on a distinguished road
i have an velocity inlet profile u(y)
but this profile isn't Analytical (i have an array u) how can I put it as a udf function?
the final result should be a u(y)u(t) so i can't use the regular profile at (define-> profiles)
thanks for the help
hillator is offline   Reply With Quote
Old   May 10, 2012, 01:37
Patrick
Patrick1 is on a distinguished road
thanks for the help
You can use a UDF with lots of IF statements. For example, if you have 4 mesh points in your inlet face at y=0,1,2,3 the UDF will be:
if y<3 then;
velocity=ArrayU(1)
if y<2 then;
velocity=ArrayU(2)
if y<1 then;
velocity=ArrayU(3)
if y<0 then;
velocity=ArrayU(4)
Obviously making this kind of UDF is best suited to a computer program if you have many mesh points, so you need to write a computer program to write your UDF for you
I think Fluent will interpolate the velocity profile if you don't have data for each meshpoint.
Patrick1 is offline   Reply With Quote
udf parabolic velocity inlet with unsteady case Faruk Beyca FLUENT 4 June 24, 2022 11:45
UDF for Velocity change at inlet haihek FLUENT 7 August 2, 2019 08:45
USED UDF for inlet velocity in 3D sara FLUENT 0 October 11, 2007 19:04
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
