April 27, 2012, 05:38 |
Heat transfer UDF
Felice
Rep Power: 16 |
Hi all,
I have a gearbox filled with oil. The motion of the internal gears heat the oil. I want to calculate the temperature distribution in the oil bath. Which BC should I set on the external boundaries (the case of the gearbox)? I do not know the temperature of the walls but only the temperature of the ambient (air). I know that the heat transfer coeff. h is depending on the delta T between the walls and the external air. If I want define that coefficient according to a known law, what should I do? Can someone help me writing an UDF? Regards F |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 06:43 |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 08:45 |
UDF for heat transfer | ranjit | FLUENT | 13 | January 18, 2007 11:36 |
UDF for Heat transfer coefficient | Dong Wenchao | FLUENT | 2 | August 23, 2006 07:35 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
