November 25, 2024, 19:27 |
Heterogeneous Reactions
Rep Power: 2 |
I have a case with Multiphase (VOF) and Species physics enabled. In the Species Model, Species Transport and Volumetric Reactions are enabled. Phase properties are provided using chemkin-import. Finite-Rate/No TCI is checked under Turbulence-Chemistry Interaction. A thremodynamics databse file has been uploaded.
In the Multiphase Model window, under Phase Interaction, there is a form to provide information on heterogeneous reaction. Under the Reaction Rate Function option, I only see two options - none or user defined. I don't see option for Arrhenius-rate. How can I get that option? Thanks! |
How are chemical reactions stored after parsing? | DanielW | OpenFOAM Programming & Development | 3 | June 7, 2018 15:39 |
Problem with Volumetric Reactions in Fluent | Kashif Rashid | Fluent UDF and Scheme Programming | 2 | December 28, 2017 01:36 |
Need Clarification regarding Volumetric Reactions in Fluent | Kashif Rashid | Fluent UDF and Scheme Programming | 0 | October 3, 2014 11:59 |
heterogeneous reaction in bubbling bed | bhaskar-iitrookee | Fluent Multiphase | 0 | February 4, 2014 00:31 |
porous medium and reactions | Valeria | FLUENT | 1 | July 10, 2009 04:58 |
