Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Adaptive Mesh 3D Dam Break Tutorial fails - need help
Old   November 16, 2024, 06:53
Default Adaptive Mesh 3D Dam Break Tutorial fails - need help
Daniel
DanielZ123 is on a distinguished road
I am new to CFD and Ansys Fluent. I am using Ansys 2024R2 Student Version and I am interested in Multiphase Flow Analysis.
I am trying to follow this Youtube tutorial, but I dont obtain the same result. I dont get any useful result at all.
The following images are supposed to show the iso-surface of the water phase volume fraction = 0.
This is frame 19 from the solution animation:
This is the next frame, where water suddenly appears in all edges:
And this is frame 56 with water all over:
The only difference i notice between the tutorial and my case is the automatic adaption interface in my 2024 version, which looks quite different to the older version used in the tutorial. I checked Ansys User's Guide Chapter 38: Adapting the Mesh and think my settings are adequately enough, but I guess the error is there, so I will show my setting below.
Automatic Mesh Adaption settings with Refinement/Coarsening Criterions
Any hints to where I need to look at to get reasonable results are appreciated.
Thanks in advance.
DanielZ123 is offline   Reply With Quote
flow over cylinder in openFoam saeed jamshidi OpenFOAM Pre-Processing 3 August 11, 2023 16:16
Fluent 2023 TUI Adaptive Mesh Refinement Commands sabrinam97 FLUENT 0 May 29, 2023 11:56
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Mesh gets out of sync during parallel 2D adaptive mesh refinement pjohannes183 OpenFOAM Programming & Development 0 November 14, 2013 05:31
