simulating a PCM container cylinder around a tube |
November 11, 2024, 19:18 |
Rep Power: 3 |
I am simulating a PCM container cylinder around a tube full of water and heat transfers between them , in the geometry analysis, which is suitable to take it as a 2d axisymmetric domain or to study it as a 3d model ( two pipes inside each other) with water in iner pipe and PCM material in the bigger pipe ?
please help |
Simulating Flow Over a Cylinder with Catalytic Wall in SU2 | bgulzar22 | SU2 | 0 | May 10, 2024 10:04 |
3D cylinder with baffles (solid no tube) - Calculating Pressure Drop | Famous | FLUENT | 3 | May 21, 2020 07:58 |
How to implement time-varying boundary conditions in an enclosed cylinder | Alejandro-FA | OpenFOAM Pre-Processing | 0 | May 14, 2020 07:29 |
Various questions and doubts about simulating Drag Coefficient of Cylinder | _Ennui | OpenFOAM Running, Solving & CFD | 11 | March 25, 2020 12:41 |
Simulating square cylinder using cartesian grid? | zonexo | Main CFD Forum | 5 | October 10, 2005 09:12 |
