Multiphase Flow - Calculation of Drag Force of Particle |
October 21, 2024, 14:12 |
Haider Ali
Rep Power: 3 |
Hi Everyone,
I am working on a problem where I need to calculate the drag force of particle. There is 2 dimensional rectangular fluid domain, two sides are considered as walls and one side is considered as inlet and other as outlet. Particle enter from inlet and flow towards outlet. I need to calculate the drag force experienced by particle. I have tried conventional method where we define drag force in report definition tab under solution menu. The particle doesn't appear in zones tab... Does anyone knows the fix to the problem Regards. |
ansys, fluent, multiphase flow |
Non spherical drag force - possible wrong particle volume | fkop | OpenFOAM Running, Solving & CFD | 0 | November 28, 2023 13:06 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow | DarrenC | CFX | 5 | April 7, 2016 15:50 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
Particle drag force | RE13 | FLUENT | 1 | February 26, 2008 15:55 |
