August 15, 2024, 10:14 |
Non-Stopping Capillary Flow
Frkn
Hello everyone,
I am currently working on a capillary flow simulation using the VOF method in ANSYS Fluent. My goal is to analyze the meniscus profile of the interface. While I am able to obtain the desired interface meniscus profile, I am encountering an issue where the flow does not stop as expected and continues to advance. Here are the details of my setup: Phases: I am simulating a two-phase flow with air and water. The surface tension between the phases is set to 0.0728 N/m. VOF Model: I am using the VOF model and have tested both the explicit and implicit volume fraction methods separately (volume fraction 1e-06). The implicit body force is enabled, interface modeling is set to sharp, and phase interaction includes wall adhesion. Solver Settings: I am using a pressure-based solver with gravity enabled. The operating density is set to the density of the lower density phase (air, 1.225 kg/m³), and the operating pressure is based on the coordinates where air is consistently present throughout the flow (101325 Pa). Boundary Conditions: I have set zero pressure at the inlet and outlet, no-slip conditions at the walls, and specified a contact angle. Discretization Schemes: Pressure-Velocity Coupling: PISO algorithm. Spatial Discretization: Pressure: Body force weighted. Momentum: QUICK and second-order upwind. Volume Fraction: Compressive. Additionally, I have not encountered any convergence issues, with residuals reaching around 1e-4. Despite these settings, the flow does not stabilize and continues to advance beyond the expected behavior. I am wondering if anyone has experienced similar issues or has any suggestions on what might be causing this problem. Thank you in advance for your help! Best regards, |
Capillary flow in open rectangular microchannel | kumar.kyutech | OpenFOAM Running, Solving & CFD | 0 | June 27, 2023 03:09 |
SU2 incompressible laminar flow | mkulcsar | SU2 | 3 | April 30, 2023 23:59 |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
Questions about FLOW 3D modeling capabilities | Dr Youssef Hafez | FLOW-3D | 0 | January 7, 2023 12:37 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
