Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to specify two different velocity of two different fluid at same inlet multiphase
Old   August 9, 2024, 03:03
Default How to specify two different velocity of two different fluid at same inlet multiphase
Kanak Raj
kanakraj is on a distinguished road
I am facing an issue with giving two different velocities at a single inlet (The problem is that it is flowing through a pipe with different liquids, i.e. water liquid and water vapour in a vertical pipe). For that, the velocity of liquid and vapour is different. I am doing it by splitting the inlet into two parts and giving the different velocities at each face of the inlet. But the results are not coming correct. Can anyone please suggest another method to do it? Thanking you.
kanakraj is offline   Reply With Quote
Artificial wall error in fluent aiden_1995 Main CFD Forum 0 January 9, 2023 15:06
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
