July 28, 2024, 17:08 |
VOF EWF DPM Coupled simulation
Is it possible to couple VOF EWF and DPM models together. The main issue is not able to set the same material property for the multiphase as well as for inert particle. Hence, EWF model can have either multiphase phase-2 material or inert particle material. Is there a way to have the same material in the multiphase phase-2 and inert particle? I am trying to model DPM-EWF interaction first and convert EWF to VOF when the EWF thickness goes above the threshold. Any help is much appreciated. Thank you Aron |
how to couple VOF and DPM ?? | cfdiscool | FLUENT | 7 | July 18, 2024 04:02 |
restarting CFDEM simulation: OpenFOAM coupled with Liggghts | atul1018 | Main CFD Forum | 0 | December 13, 2021 05:51 |
What to use- VOF or DPM for liquid spray from an injector? | amoli123 | Fluent Multiphase | 4 | December 16, 2020 06:15 |
Dambreak case can't be simulated by the simple coupled level set and vof (sclsvof) | saatt | OpenFOAM Running, Solving & CFD | 1 | January 21, 2018 18:40 |
Steady state simulation with VOF method | Gottkanzler | Fluent Multiphase | 2 | June 14, 2017 09:32 |
