Completely different results from the same analysis in two systems? |
July 20, 2024, 16:34 |
I have a 2-phase analysis in Fluent that has already been solved on one system, and when I re-solve it on my system, the results are different.
I don't make any changes to the analysis and just start calculating. The results are quite different. Does anyone have experience with this? (My analysis is about the turbulence of the fluid and the forces that are applied to the wall due to the movement of the fluid) |
fluent - udf |
icoFoam and pisoFoam have different results in laminar analysis | siavash_mansouri | OpenFOAM Running, Solving & CFD | 0 | March 8, 2023 14:51 |
bad heat transfer results with low y+ | me45 | OpenFOAM Running, Solving & CFD | 0 | April 29, 2020 11:56 |
Coupling AcuSolve (Output .h3d results) with SimLab for Linear Static Analysis | gaddora165 | Main CFD Forum | 0 | March 5, 2020 13:16 |
Save Results of harmonic analysis with APDL command | ansyxyz | ANSYS | 0 | June 7, 2017 05:24 |
Saving bulk results on a plane as a function of time in transient analysis | cfd1980 | Autodesk Simulation CFD | 3 | June 23, 2015 09:44 |
