July 13, 2024, 23:10 |
DPM for cyclone separators
Elhussien
Greetings all,
I'm simulating a cyclone separator, I had created un unstructured hexahedral mesh and adjusting the solution model to be RSM. I started the solution with steady gas only in the model with coupled pressure solver until convergence of 1e-5. Now I want to start particle injection to simulate the separation with several loadings, I mean from dilute loading "one-way coupled" then much higher "two-way" and finally some 4-way coupling. My problems: 1- some concerns -not clearly showed in fluent guide - about particle treatment. 2- How exactly determine both separation eff. and pressure drop? and when to stop? |
Experience/tip: DPM being tracked on every iter despite model settings | tbraun84 | Fluent Multiphase | 1 | March 12, 2024 04:34 |
divergence issue when updating dpm sources | mohamadalimirzaei1994 | Fluent Multiphase | 0 | August 17, 2020 12:53 |
Confused between DPM and multiphase flow | pchoopanya | FLUENT | 0 | June 21, 2019 04:44 |
how to use DPM from DPM file unsteady? | Cloud | FLUENT | 0 | November 10, 2011 04:25 |
slow after mesh for enhanced wall treat DPM | joshkemp | FLUENT | 0 | May 1, 2007 17:20 |
