Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian Multiphase yields different pressure drops
Old   July 7, 2024, 15:16
Default Eulerian Multiphase yields different pressure drops
karl
SnekaySquid is on a distinguished road
I have been trying to get some Pressure drops in a vertical pipe, and for what ever reason, When I use Eulerian Multiphase I get desired pressure drop of 3200Pa. However, I know I don't need multiphase for this to work (I am only using water no other materials)
If I run the same parameters without multiphase on, I get a pressure drop of 1Pa.
has this happened to anyone else, and is there a fix for it?
SnekaySquid is offline   Reply With Quote
error, multiphase flow, pipe flow, pressure drop
Multiphase Flow with high pressure drop and transition Xsoliv Fluent Multiphase 0 January 13, 2021 14:23
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
Negative pressure in Eulerial multiphase model hongyingli FLUENT 0 September 5, 2011 06:29
Help: floating pressure, multiphase, closed domain memahfud FLUENT 1 September 24, 2009 04:38
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
