July 3, 2024, 05:37 |
Two phase Simulation convergence
Muhammmad Waris
I am doing a simulation for flow boiling in a vertical rectangular annular channel with a single heater rod in the center. R134a is the working media. RPI boiling model is being used. The geometry is a simple 2D rectangular with one side as wall and the opposite side as heat flux and adiabatic partitioned. I have to simulate both natural and forced convection cases. The issue is that the solution diverges as it is started. I have tried changing everything but cannot figure out where the problem is. Is there an issue with my material properties, boundary conditions or other parameters.
Boundary conditions I am using are Inlet: Velocity inlet (o for natural convection) Outlet: outflow Wall Operating pressure is 2.6 MPa and T_sat at this is 80 C. Kindly help in this regard. |
convergence issue, forced convection, natural conection, rpi wall boiling, two phase boiling |
Failed to converge in Fluent Multiphase Granular 2nd phase | jonshontwin | Fluent Multiphase | 1 | November 18, 2021 06:44 |
CFG file Set Up | Nicola_Fontana | SU2 | 5 | November 16, 2021 12:48 |
Fatal overflow in linear solver and simulation never show convergence | Wong0912 | CFX | 1 | March 2, 2021 16:59 |
indoor simulation convergence problem | jhlee9622 | FLUENT | 0 | July 3, 2017 03:44 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
