Gravity vortex turbine simulation performance |
June 30, 2024, 20:35 |
Juan Pérez
I am working on simulating a gravitational vortex turbine in ANSYS Fluent using the SST K-OMEGA turbulence model. The geometry consists of 4 interfaces with a total of 3716725 mesh elements. The simulation is transient, with constant inlet velocity and rotor rotational speed (mesh motion). The phase interaction (water and air) considers a surface tension coefficient of 0.032Nm and a "continuum surface stress" in the "surface tension force modeling". To optimize performance, the SIMPLE scheme and first-order equations have been used for the solution of the momentum, turbulent kinetic energy, and specific dissipation rate variables. I have performed both fixed and adaptive simulations with a maximum of 100 iterations per time step. The time step size is 0.0001s for the fixed simulation and 0.00001s for the adaptive one, with a "global courant number" of 3 for the latter. Although the simulation converges correctly without errors, the simulation time is extremely slow. Simulating 3 seconds in transient takes about 250 hours in real time. Question: Are there any suggestions to improve the simulation performance? Is it necessary to modify any parameters or settings to reduce the calculation time? Additional Information: ANSYS Version: 2024 R1 Processor: Intel(R) Xeon(R) Silver 4216 Logical Processors: 64 RAM: 128GB Your suggestions are very much appreciated. |
cfd, fluent, vof |
Simulation of Water Turbine with CFX | hydroturbines | CFX | 2 | November 18, 2024 02:18 |
numerical simulation with Ansys Fluent of a 3D GORLOV water turbine in two-phase flow | khadija8 | FLUENT | 1 | November 17, 2020 20:32 |
FSI simulation of wind turbine blade using NLH method | Ko_Shine | Fidelity CFD | 3 | April 22, 2020 08:08 |
Vertical axis water turbine simulation | SHIKHA BHUYAN | ANSYS | 0 | September 16, 2014 02:06 |
Vertical axis water turbine simulation | SHIKHA BHUYAN | CFX | 1 | September 15, 2014 08:40 |
