Fluent calculates cavitation flow with negative absolute pressure inside the cavity |
Hou DF
Rep Power: 4 ![]() |
I used UDF and overset meshes to define a cylindrical sailing body moving at high speed in water (about 100 m/s), taking into account the cavitation effect from the high speed movement. I used the S-S cavitation model to calculate the uncompressible flow, using transient calculations with a mean value of 10 for the value of wall Y+ and used a time step of 1e-7 s. I tried to show the true pressure inside the cavity using the tui command: Display clipped pressure in the post-processing [yes]no but the calculations showed a negative pressure. A real pressure less than 0 should not be generated in a real physical field, so how does this situation occur? Any thoughts on how to solve this? I've been puzzling over this for a while, so any insights you could share would be much appreciated. Hou |
absolute pressure, cavitation bubble, overset fluent, udf cg motion |
Negative pressure rise across blower | 310toumad | Main CFD Forum | 2 | July 30, 2024 22:46 |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
Pressure driven flow through a valve: pressure BCs clarification | Coraz94 | FLUENT | 1 | December 17, 2020 05:37 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
