"steady/repeat periodic flow" from transient simulation for multiphase flow ? |
LYH
Rep Power: 2 ![]() |
I am running 2-pahse flow simulation using ansys fluent.
I tried both steady and transient setting. 1. Transient After several trials, I set the transient simulation as follow: For "Fixed" type Number of time steps: 2e5 Time step size: 1.25e-6s Max iterations per time step: 25 At the same time I run "Adaptive" type : Number of time steps: 2e5 Initial time step size: 1.25e-6s Number of fixed time step: 1s Minimum time step size: 1e-8s Maximum time step size: 1s Max iterations per time step: 100 2. Steady Cannot converge unless time-step size set smaller than 1e-10, which is nmearly impossible for me to run in such slow computing. From the volume fraction results, I observed that the flow seem to have "pseudo repetition pattern" at certain period of time. But it may not occur constantly and frequently My question are : 1. How to determine transient simulation has reached "steady, no change over time" or "pattern over a length of time repeating unconstantly over period" ? 2. Where it starts / How long the 'length of time' that recurring pattern occurs ? 3. How to verify that the "steady/repeat periodic flow" are enough to descirbe the case ? 4. Is there any other way to speed up the calculation process (eg: set time step size much bigger than 1.25e-6, set higher tolerance? but able to converge)? Any suggestion are welcome. Thank you in advance. View my previous replies: Transient simulation -> Steady state solution |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
Setting a mass flow with periodic boundary conditions (3D) | Flex | OpenFOAM | 2 | April 10, 2022 12:46 |
Transient Flow Simulation Ahmed Body | FinlayEeles | Main CFD Forum | 4 | July 2, 2021 07:10 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
Simulation of transient cavitating flow around a hydrofoil | kimotbwb | Main CFD Forum | 0 | January 28, 2013 15:04 |
