Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mole Fraction inlet is different from boundary conditions
Old   March 28, 2024, 08:56
Question Mole Fraction inlet is different from boundary conditions
HelloHelo is on a distinguished road
Hi! I've been simulating a gas entering a liquid through small holes. I'm using the Eulerian model, but I also simulated using the mixture model. In both situations, I set the mole fraction of component X in the gas at the inlet boundary conditions. However, when I start running the calculation, the mole fraction at the inlet surface of component X is different from the one I set. I've tried activating the diffusion inlet, but it didn't work either.
HelloHelo is offline   Reply With Quote
Old   April 1, 2024, 17:09
Sebi
bloodflow is on a distinguished road
Are you 100% you haven't specified it as a mass fraction? The default input to species is mass fraction, not mole fraction. Alternatively, Fluent is probably lying to you, if you are generating this output before solving for >1 iteration.
bloodflow is offline   Reply With Quote
Old   April 4, 2024, 19:50
I am sure. There is a box you check to input as mole fraction. I've run some other tests and now it only changes to something different from my input when I activate the reactions. But I don't think the inlet should change once it's just got in contact with the other component.
boundary condition, gas, inlet, mole fraction
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
