Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian Wall Films UDF for condensation mass flow rate
Old   March 25, 2024, 10:19
Default Eulerian Wall Films UDF for condensation mass flow rate
Isacco Rafanelli
iraf is on a distinguished road
Dear members,
I am using the Eulerian wall films model to estimate the condensate flow rate in a vapor-only mixture in contact with a wall with temperature below saturation. I would like to implement some UDF models to externally calculate the condensate flow rate, however, it is not clear to me which type of "DEFINE_XXXX" UDF I should use.
Any suggestions?
Thank you
iraf is offline   Reply With Quote
condensation, eulerian wall films, phase change, udf, user defined functions
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Surface Integrals of Species Mass Flow to Wall Incorrect koad FLUENT 4 January 12, 2016 17:38
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 03:07
