Divergence while simulating falling 2D ball into water using overset and dynamic mesh |
March 23, 2024, 14:01 |
Saheb Bedi
Hi everyone, so i'm new to multiphase and VOF and this is the first problem i'm trying to tackle.
I'm basically trying to setup the case as in the video and I've also used the same exact dimensions and mesh size. (https://www.youtube.com/watch?v=n8yuokXHObE) But unlike in the video I've created the geometries seperated and meshed. I loaded the bg mesh first and then appended the component mesh and created the overset interface. The residuals always diverge and fluent returns with the error Update Dynamic Mesh Failed:Negative cell volume detected. N cells with non-poisitve volume detected. I have also changed overset verbosity settings and the report shows N number of oprhan cells in interface overset-intf. Ive tried decreasing the time step as well but all it does is delay the divergence and again solution diverges when the overset bound ary hits the interface. I've also used laminar and k epsilon model What I've noticed is that the liquid interface starts behaving abnormaly as soon as the overset boundary of the component(ball) touches the interface. Other errors that i get are: 6DOF angular solver has not converged Turbulent viscosity limied in N cells Last edited by sahebbedi; March 23, 2024 at 14:08. Reason: Missed some info and a pic |
DTCHull Ship Resistance Tutorial - Morphing vs Overset Dynamic Mesh | myozinaung | OpenFOAM Running, Solving & CFD | 34 | July 9, 2024 10:48 |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 15:08 |
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca | insane | OpenFOAM Running, Solving & CFD | 0 | May 17, 2020 22:35 |
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour | Caster_Troy | FLUENT | 1 | December 7, 2017 06:19 |
[Star-CCM+ v9] Dynamic Overset Mesh basic problem | johncoffey | STAR-CCM+ | 5 | June 17, 2014 14:14 |
