Lee evaporation model gives unrealistic wall superheating |
February 28, 2024, 03:53 |
marcus aurelius
Rep Power: 3 |
I am using Lee evaporation model to simulate saturated pool boiling case for dielectric fluid. I am using constant wall heat flux boundary condition.
When, I am plotting Heat flux vs Wall superheating, I am getting unrealistic too high wall superheating compared to the experimental value. For example, at heat flux of 200 kW/m2, the wall superheating should be 14 °C, But I am getting around 145°C of superheating. I know the lee coefficient is sensitive here. I did trial and error with different values ranging from 0.1 to 1000 but, the wall superheating never goes near to 14°C, it is always above 100° (which is unrealistic). How do I deal with this issue? |
March 20, 2024, 12:44 |
Rep Power: 17 |
I guess there could be quite a few more parameter apart from simply the Lee coefficient which might be important ...
How are you modelling the bubbles, interfacial area, lift and drag / buoyancy forces? |
March 21, 2024, 07:20 |
marcus aurelius
Rep Power: 3 |
Thank you for the reply. But, I have been able to manage the wall superheating near to realistic values by adding solid wall (conduction).
boiling, evaporation condensation, fluent, lee model, multiphase |
Does the Lee model for evaporation guarantee a correct total evaporation volume? | lzhaok6 | Main CFD Forum | 0 | March 16, 2023 04:30 |
Lee evaporation model in Ansys CFX with CEL expressions | SteffenBcfd | CFX | 3 | October 26, 2022 06:46 |
evaporation rate in wall film vaporization model | tmy | CONVERGE | 2 | November 13, 2018 11:52 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 12:55 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
