February 26, 2024, 05:06 |
Help - Flushing a blocked/clogged pipe
Mike
Hi there,
I'm a student who is new to fluid simulation and working with Ansys Fluent. For a project, I'm trying to figure out how to model multiphase flow with the example of "flushing a clogged pipe". At the moment I'm using the VOF model because I assume that both phases are liquid. I've attached a picture of a simulation, but the flushing medium (water) in blue seems to stick to the walls of the pipe. Why does this happen? The interface Modeling is Sharp, I'm working with a constant surface tension coefficient and the option "surface tension Force Modeling with continuum Sufrace Force" is enabled. Any tips are appreciated! Thank you! |
help for a newbie, multiphase flow |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 23:14 |
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam | wuyangzhen | OpenFOAM | 10 | December 12, 2017 01:19 |
Double Walled Pipe Boundary | dahvqaz | FLUENT | 2 | December 5, 2012 11:14 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
