Fluent Material Properties Reference Temperature for RPI Boiling Model |
February 20, 2024, 01:23 |
Nirmal
I'm validating the RPI boiling model based on the Bartolemei Experiment (https://www.researchgate.net/publica...g_ANSYS_Fluent). I created two materials (water liquid and water vapor) and specified the liquid properties as a function of temperature and vapor properties as constant at the saturation point (558K).
My question is in the material properties what temperature should I enter for the reference temperature? Is it default value (298.15 K) or the saturation temperature (558 K)? I entered the standard state enthalpy value as 0 for liquid. The standard state enthalpy value entered for vapour is 2.7e7 (latent heat multiplied by MW). Whether reference temperature for both the materials should be changed or only for the vapor I should enter as 558K? |
Averaging over iterations for steady-state simulation | CFD student | Fluent UDF and Scheme Programming | 8 | September 22, 2022 03:39 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 21:05 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
