How to write a momentum source UDF - Eulerian multiphase model |
Juan Torres
Rep Power: 0 ![]() |
I need help implementing a UDF to insert the gas phase momentum source term.
I have three phases: -Primary phase - Alkaline water -Secondary phase - Hydrogen -Secondary phase - Oxygen 1) Is it possible to use this term as an input parameter through "Named expressions"? 2) Any alternative or reason why the code is not even initializing (it appears to be a memory error as the multiphase model is only valid in parallel after version 2018/2). It is a dispersion force similar to the turbulent dispersion model of Burns et al. It is calculated by: Fd_x = - [(Fraction of liquid or gas) * (density_liquid) * (Coef_Dispersion) * (Mag_vel_relative) * (Gradient_void fraction)] / (db_diameterbubble) #include "udf.h" DEFINE_SOURCE(disperse_force_x, c, t, dS, eqn) { real F_DB_x; real epsilon_water, epsilon_h2, epsilon_o2, density_liq, K_h2, K_o2, Vr_mag, grad_epsilon; real db = 0.000058; // Bubble diameter [m] #if !RP_HOST Thread* liq_thread, * h2_thread, * o2_thread; int phase_index = -1; #endif // Coefficients and problem properties epsilon_water = C_VOF(c, t); // Water fraction liq_thread = THREAD_SUB_THREAD(t, 0); // Liquid phase thread h2_thread = THREAD_SUB_THREAD(t, 1); // Hydrogen phase thread epsilon_h2 = C_VOF(c, h2_thread); // Hydrogen fraction o2_thread = THREAD_SUB_THREAD(t, 2); // Oxygen phase thread epsilon_o2 = C_VOF(c, o2_thread); // Oxygen fraction density_liq = C_R(c, liq_thread); // Liquid phase density K_h2 = 9.0 * db; // Hydrogen dispersion coefficient (K_h2/db) K_o2 = 4.0 * db; // Oxygen dispersion coefficient (K_o2/db) // Obtaining the phase index of the cell using THREAD_STORAGE phase_index = *((int*)THREAD_STORAGE(t, SV_CELL)); #if !RP_HOST // Calculate the gradient according to the cell phase if (phase_index == 1) { // If the cell contains H2 grad_epsilon = C_VOF_G(c, h2_thread)[0]; // Gradient for hydrogen } else if (phase_index == 2) { // If the cell contains O2 grad_epsilon = C_VOF_G(c, o2_thread)[0]; // Gradient for oxygen } else { // If the cell contains water or other phases grad_epsilon = C_VOF_G(c, liq_thread)[0]; // Gradient for water } // Calculate the relative velocity between gas and liquid phases if (phase_index == 1) { // If the cell contains H2 Vr_mag = sqrt(pow(C_U(c, t), 2) + pow(C_V(c, t), 2)); // Module of the relative velocity for hydrogen F_DB_x = -epsilon_h2 * density_liq * K_h2 * Vr_mag * grad_epsilon / db; } else if (phase_index == 2) { // If the cell contains O2 Vr_mag = sqrt(pow(C_U(c, t), 2) + pow(C_V(c, t), 2)); // Module of the relative velocity for oxygen F_DB_x = -epsilon_o2 * density_liq * K_o2 * Vr_mag * grad_epsilon / db; } else { // If the cell contains water or other phases Vr_mag = 0.0; // Set the relative velocity to zero for the water phase F_DB_x = -epsilon_water * density_liq * K_h2 * Vr_mag * grad_epsilon / db; } #endif // Define the momentum source term in the x-direction momentum equation dS[eqn] = 0.0; // There are no momentum sources on the surface if (eqn == 0) // Momentum equation in the x-direction return F_DB_x; else return 0.0; } |
c_vof_g, gradient vof, udf |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
