Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Solution diverges when mesh is refined
Old   February 1, 2024, 02:54
Default Solution diverges when mesh is refined
marcus aurelius
marcusaurelius is on a distinguished road
I am trying to do a saturated pool boiling simulation on a finned surface using ANSYF Fluent VOF Lee evaporation-condensation model.
I got some initial results without problem with coarse mesh. But, when I refined the mesh to 2 times, the solution diverges at initial time steps itself.
I tried reducing the time step (up to 10^-9) and tried first order as well as second order schemes. Also tried switching off turbulence model.
I can't understand, how its perfectly working for coarse mesh and blows up for finer mesh with same setup?
The pictures for coarse and fine mesh are attached. The snapshot of how resudual are shooting up is attached.
marcusaurelius is offline   Reply With Quote
Old   February 1, 2024, 10:26
Joern Beilke
JBeilke is on a distinguished road
10^-9 seems far too small. It often helps to increase the time step size at the beginning of a simulation instead of decreasing it.
JBeilke is offline   Reply With Quote
ansys fluent, evaporation condensation, lee model, multiphase, volume of fluid
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
Converging the solution aja1345 FLUENT 13 June 15, 2022 00:46
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
