Experience/tip: DPM being tracked on every iter despite model settings |
January 29, 2024, 15:46 |
Tim
Rep Power: 8 |
This is completely obvious in retrospect, but it had me scratching my head for an hour or so...
If you create a solution report with dpm data and assign it to a plot or file (default is both turned on with a sampling interval of 1), the sampling interval will drive the dpm updates. So, you may have your dpm update interval set to 10 or 100, but Fluent will perform a dpm iteration every time it needs to update that solution report plot and/or file. If you are wondering why your model is performing a dpm iteration at every fluid iteration and your dpm update interval is set to something higher, check your report definitions. |
March 12, 2024, 04:34 |
#2 | |
dpm update, solution report |
porous medium model and DPM model | yzw | Main CFD Forum | 0 | September 22, 2023 08:02 |
Effect of the MHD model on DPM particles | cdsomer | FLUENT | 0 | March 23, 2023 08:50 |
Fixed Temperature Constraint problems for coal combustion | yglovella | OpenFOAM | 0 | February 16, 2023 01:00 |
Choosing mixture model vs. DPM dodel in fluent | chloe0043 | Main CFD Forum | 0 | July 19, 2022 05:01 |
DPM and species transport model | Achini | Fluent Multiphase | 1 | December 12, 2020 01:28 |
