Conjugate Heat Transfer with Eulerian RPI Wall boiling model |
January 17, 2024, 06:05 |
marcus aurelius
Rep Power: 3 |
I am trying to simulate subcooled flow boiling inside a tube using Eulerian Multiphase RPI model. There is solid wall (steel) and fluid domain (water-vapor). I created the mesh and imported in the Ansys Fluent.
But, Fluent considers the solid steel as mixture (of phase1 and phase2). How do I properly define these solid-fluid regions/interfaces? The screenshot of cellzone attached. The mesh settings are also attached. (I know I can do simulation without considering solid part, But it's kind of important for me because further simulations will required conduction in Fins). |
January 21, 2024, 10:34 |
Pierre LECHEVALIER
Rep Power: 3 |
Dear MarcusAurelius,
I do not have Fluent open so i am not sure. I think you have two domains in your Fluent configuration (fluid and solide), is not it ? Can you see the solid domain in your post-processing options ? Basically, i am not sure that the "mixture" phase you saw means that Fluent consider it as a mixture of phase 1 and 2... Best regards, Pierre |
ansys, boiling, conjugate, fluent, multiphase |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
