Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Water Injection to Superheated Steam
Old   December 18, 2023, 00:57
Default Water Injection to Superheated Steam
JaheKucing is on a distinguished road
I'm trying to model an injection of water to a stream of superheated steam. I'm using VOF Model, with Lee condensation model for the phase interaction. The material properties are set to constant first as i'm still new to this kind of simulation. the turbulence model i used is k-epsilon realizable. For context, here are the design conditions:
Superheated steam inlet:
Pressure: 7.7 Bar abs
Temperature: 5 degree Celcius above saturation temperature (sat. temp. 168.835 deg. C)
mass flow rate: 80 kg/s
This steam is to be lowered to saturated temperature by injecting water at 30degC with injection pressure 1 bar abs above steam pressure. by calculating using heat and mass balance equation, the water flow rate needed is 0.397 kg/s
I use velocity inlet for both the steam inlet and water inlet, and pressure outlet. the scaled residuals fluctuated and wont go down, what can i do?
JaheKucing is offline   Reply With Quote
superheated, vof
DPM water injection Alessandro_Lamberti FLUENT 3 May 25, 2023 06:16
Problem condensation/ evaporation (condensate water vapor) bigfoot47 FLUENT 0 October 21, 2019 09:07
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
Ricardo Wave Water Injection Simulation randomspeedfreak Main CFD Forum 0 April 2, 2015 13:20
Water injection Reza_computational CFX 1 October 28, 2010 19:21
