Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase convergence
Old   December 10, 2023, 06:16
Default Multiphase convergence
SphericalCube is on a distinguished road
Hi all,
So, I am trying to do a multiphase simulation, more specifically, a bubble column that includes the PBE. The problem is solved transiently, however, I am only interested in the 'steady-state' solution.
I am able to get the thing to converge. But compared with experimental data and CFD studies that solved the same setup the results are not quite right.
I have been looking for tips and tricks/strategies to get the multiphase simulations to converge correctly. But I haven't found much, except a little in the Fluent users guide.
What I'm doing right now is to first compute an initial solution with 1st order schemes and without the PBE, then I continue the solution with higher order schemes for some time, and last, add the PBE.
I was wondering if this is an okay approach? Does adding in the higher order schemes actually "refine" the solution. Or should I maybe try to start the simulation with higher order schemes instead? Is it okay to add the PBE in later?
Also, any general tips or literature on how to get multiphase solutions to converge to the correct solution would be much appreciated!
SphericalCube is offline   Reply With Quote
convergence, multiphase
axial compressor mass flow convergence issue jyotir SU2 5 July 5, 2024 10:06
Convergence Problem for Multiphase flow Naveen Cheruku STAR-CCM+ 2 November 15, 2023 03:53
Continuity convergence issue for a multiphase flow in a counterflow heat exchanger Andrea1984 Fluent Multiphase 2 July 24, 2013 05:55
Multiphase Convergence Issues RodriguezFatz FLUENT 2 March 11, 2013 01:00
Force can not converge colopolo CFX 13 October 4, 2011 23:03
