Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Ansys Simulation of Adsorption through Porous Packed Bed
Old   November 8, 2023, 10:37
Default Ansys Simulation of Adsorption through Porous Packed Bed
heppapig is on a distinguished road
Hi, I need help with a project. It is about simulating adsorption using a porous packed bed. I can't seem to figure out how to do it.
This is what I've done so far...
I used multiphase model and species transport. For species transport, I created a mixture of water and mercury with mercury being the component adsorbed to the packed bed. For multiphase, I chose Eulerian in which my phase 1 is the mixture while the phase 2 is the porous packed bed. In phase 2, I defined it as granular and packed bed. I also enabled mass transfer mechanism (species transport) in which specie (mercury) will go to phase 2. When I try to run the simulation, it won't work as the Ansys fluent will crash. What am I doing wrong? How to properly simulate adsorption?
I've also tried to enable multiphase but without species transport and vice versa. The simulation gives a floating-point error. Sometimes, it run well but it doesn't seem to give correct results. I want to see if mercury will adsorb onto the porous bed. Also, is it possible to input adsorption isotherm in Ansys? If so, how? If no, does Ansys calculate for it? I am very new to Ansys, please bear with me. Your response will be a big help for our project. Thank you.
heppapig is offline   Reply With Quote
2Phase flow simulation in Porous Media Ansys Fluent Yaqub FLUENT 0 June 22, 2017 04:46
Ansys Workbench Thermal-Stress Coupling - 2D Hot Rolling simulation Jeronimo97 CFD Freelancers 4 August 23, 2014 21:30
Porous Media Simulation with CFX/Fluent Ghasem ANSYS 1 May 14, 2013 10:07
CFD analysis of packed bed reactor with porous catalysts goswami.sandeepan Main CFD Forum 1 November 30, 2011 09:17
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? Chander CFX 3 November 28, 2011 15:26
