Facing problem in initialization of case flow boiling through vertical heated pipe |
September 20, 2023, 03:17 |
Aakash Rana
Hi everyone,
I'm simulating flow boiling regime transition through vertical pipe. My case is like, initially pipe is filled with heated air then subcooled water liquid starting to enter from the bottom of the pipe. I've setup the model using water liquid as a primary fluid but I'm unable to initialize the problem correctly. Fluent taking primary liquid in the whole mesh region and if I give volume fraction of air as 1 during initialization then mixture volume fraction reaching to value 2 and results in floating point exception. Fluent is also not allowing to have air(gas) as a primary fluid and not allowing to patch the primary fluid. I've tried using cell registry also, but initialization result was same. Please help me out! |
boiling flow, flow through pipe, multiphase modelling, rpi wall boiling |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Problem with pipe flow simulation with wedge shaped domain and recirculation bubbles | sahmed | OpenFOAM Running, Solving & CFD | 0 | August 17, 2016 14:56 |
3D Pipe Flow Problem: Velocity profile is not symmetric | malicemethods | FLUENT | 0 | May 27, 2015 11:51 |
simpleFoam pipe flow case doesn't converge | me3840 | OpenFOAM Running, Solving & CFD | 5 | February 8, 2014 13:54 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
