Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mass imbalance in Volume of Fluid
Old   August 17, 2023, 05:34
Default Mass imbalance in Volume of Fluid
Sumit Sharma
sumit.sh is on a distinguished road
I am trying to simulate evaporation in a plate heat exchanger using the Volume of Fluid model and the LEE model for phase change. As the LEE model is empirical, we must specify the evaporation and condensation frequencies. When the frequencies are low (default 0.1), the solution and mass imbalance converge. However, on increasing the frequencies to higher orders, I encounter reversed flow, and the mass imbalance takes a severe hit and keeps oscillating. I have tried improving the mesh quality near the outlet and extending the outlet sufficiently, but nothing seems to work. Following are the boundary conditions and setup
General:
Steady-state, pressure-based solver, gravity
Multiphase:
VOF, implicit, 2 phase, Surface tension modelling, Evap/Cond (Tsat)
Boundary Conditions:
Operating Pressure (Psat)
Inlet: Mass Flux (G_liq and G_vap at Tsat)
Outlet: Pressure outlet (Psat), vapor Backflow volume fraction = 0
Wall_Thermal: heat flux
Wall_Momentum: No slip, contact angle for wall adhesion 1° (highly wetting fluid)
I start by solving the single-phase flow and then use the flow profile for the multiphase simulation. I keep the URFs low initially and increase them gradually.
Any suggestions will be highly appreciated. Thanks in advance.
-SS
sumit.sh is offline   Reply With Quote
Old   April 24, 2024, 04:49
Abdullah hassan
Abdullah hassan is on a distinguished road
Hi Sumit. Sh,
Did you find the solution?
I am also stuck at the same position and nothing is working for me either.
Abdullah hassan is offline   Reply With Quote
evaporation condensation, mass balance, multiphase flow, reversed flow., volume of fluid.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Calculating source term total cell-zone volume parallel computation RobV Fluent UDF and Scheme Programming 2 May 30, 2022 04:46
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
