August 10, 2023, 12:31 |
Help, Population balance model, Kernel
Matias
Rep Power: 5 |
Hello, I am working with a multiphase model using the Eulerian approximation, the continuous phase corresponds to water while the other phases are air and a mixture.
My question is the following: Is it possible to use for each secondary phase a different coalescing kernel? I see that in inhomogeneous PBM it allows entering two phases but it does not allow a specific kernel to be applied for each phase. for the air phase I want to apply the Prince and Blanch coalescence, and for the mix I want to apply a kernel defined by a UDF. Thank you so much. |
eulerian, kernel, multiphase, pbm, population balance model |
Coupling RPI wall boiling model with population balance model in Fluent | softice2006 | Fluent Multiphase | 1 | April 19, 2023 03:09 |
Population Balance Model | Agisfit | FLUENT | 0 | March 24, 2023 09:20 |
agglomeration using Population balance model | Abdullah Tasleem | ANSYS | 0 | May 19, 2022 03:18 |
Population balance model for twofluid model | pierre | OpenFOAM Running, Solving & CFD | 9 | March 19, 2016 14:46 |
UDF for the population balance model | Hossam | Fluent UDF and Scheme Programming | 0 | March 27, 2009 03:46 |
