Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Boiling in a pipe
Old   August 5, 2023, 11:25
Red face Boiling in a pipe
Hassan Tariq
htariq is on a distinguished road
Hi everyone!
I am stuck with the boiling in a pipe problem in Fluent. Fluid is water at atmospheric conditions and heat flux is applied to wall which is well blow the critical heat flux...
Niether rpi model nor non equilibrium model is converging..
Pipe is vertical
Fluent boiling model with default forces
Velocity inlet
Pressure outlet, 0 Pa gauge
1e-5 surface roughness
Need some suggestions
Thanks
htariq is offline   Reply With Quote
Old   September 9, 2023, 06:55
Default Same problem with me
Ankur
h_ankur is on a distinguished road
Same problem with me but with a horizontal pipe
h_ankur is offline   Reply With Quote
Old   September 9, 2023, 06:56
Default Getting reverse flow at the outlet
Ankur
Getting reverse flow at the outlet and pressure divergence with complete divergence of the solution
Old   September 10, 2023, 12:42
Hassan Tariq
are you doing pseudo transient?
could you share the tutorial that you are following?
Old   September 11, 2023, 03:29
Ankur
No, I am using purely transient case. And i do not have any tuttorial to following, i was following the research paper "Pal, R.K. and Kumar, R., 2021. Thermo-hydrodynamic modeling of flow boiling through the horizontal tube using Eulerian two-fluid modeling approach. International Journal of Heat and Mass Transfer, 168, p.120794." but unable to reproduce the results. If anyone can help, I will be highly grateful.
Old   March 20, 2024, 09:51
Oscar Zagal
oscar_zagal is on a distinguished road
Hello
Maybe you can try with OpenFOAM v2312, I had the same problem working with Fluent, but in OF there are a tutorial called solidQuenching2D in the solver for heat transfer chtMultiRegionTwoPhaseEulerFoam that allows me to reproduce the paper of Kumar, the only problem is that you will need a very powerful computer because the solver only work transient simulation
Edit: and pseudo transient if you know how to use the PIMPLE algorithm
oscar_zagal is offline   Reply With Quote
Old   August 24, 2024, 07:22
zaint18 is on a distinguished road
Did someone figure out a fix to this?
zaint18 is offline   Reply With Quote
boiling, fluent rpi model, pipe
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 23:14
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 01:19
boiling in pipe (UDF) malay Fluent UDF and Scheme Programming 2 November 13, 2016 07:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
