A rigid body moved by water within a dynamic mesh. |
June 29, 2023, 03:00 |
A rigid body being moved by water within a dynamic mesh.
Iraq
Rep Power: 6 |
Dear all, I have a cylinder involving a piston being moved by water, as depicted in Figure 1. The water exerts a force on the piston, pushing the water located behind the piston towards the outlet. The mesh employed has an element size of 0.15 mm. I have compiled a User-Defined Function (UDF) in ANSYS Fluent for the properties of water density, water sound speed, and the motion of the piston as a “rigid body” as in the corresponding TXT File. Most simulation settings are in figures 2 through 9. The time step is 0.001 sec.
In my attempts to solve this problem, I have explored three different solution methods: SIMPLE, PISO, and Coupled. Unfortunately, all three methods have yielded the same result – convergence has not been achieved. I kindly request assistance from anyone who can identify the errors in my work. Furthermore, I would appreciate guidance on how to correctly implement this simulation. Thank you in advance for your support. Last edited by ymya; July 16, 2023 at 10:40. |
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh | tomyangbath | FLUENT | 18 | October 12, 2016 07:57 |
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues | nathanricks | ANSYS Meshing & Geometry | 0 | September 23, 2015 06:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[ICEM] Rigid sphere falling through air. Dynamic mesh | alexmeier | ANSYS Meshing & Geometry | 5 | June 30, 2010 01:23 |
