Eulerian multiphase model momentum divergence |
June 20, 2023, 04:55 |
Muhammad Faizan
Rep Power: 8 |
Dear friends
I am trying to simulate PEM water electrolysis with Eulerian multiphase model, where anode side is fed with liquid water and oxygen is the product at anode and hydrogen at cathode. Based on this, I defined inlet at anode as liquid water which is defined as the primary phase and oxygen as the secondary phase. Since there is no oxygen inlet, my inlet boundary condition is primary phase (water) inlet velocity and the secondary phase (oxygen) volume fraction is defined as 0 and velocity is also 0. Based on the faradaic law, I defined the mass source term for both primary phase (water) and the secondary phase (oxygen) as -j/2F and j/4F respectively. When I run the fluent, the volume fraction of secondary phase instantly reaches 1 and primary phase as 0 causing momentum divergence. I have attached the screenshot of model I am using. Please help me fix it. viscous: laminar: model: Eulerian (2 phases) Implicit formulation Drag: schiller-naumann Lift: saffman-mei Wall Lubrication: antal-et-al Heat, Mass: none surface tension: 0.072 Interfacial Area: ia-particle methods.JPG residual.jpg gas-fraction.jpg gas-velocity.jpg Thanks Faizan |
bubble flow, electrolysis, eulerian, multiphase |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 5 | November 22, 2024 07:32 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Restitution factor in Eulerian multiphase model | m.jahedi | FLUENT | 0 | February 7, 2012 10:43 |
modelling solids viscosity in eulerian multiphase model | derkaiser | FLUENT | 1 | December 5, 2011 04:42 |
Lift coefficients for Eulerian Multiphase Model | Anastasios Georgoulas | FLUENT | 0 | July 14, 2008 07:13 |
