Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluent DPM particle tracking time step
Old   May 18, 2023, 10:09
Default Fluent DPM particle tracking time step
WEST BENGAL
Kuntalika is on a distinguished road
Hi, I am using fluent discrete phase model for particle-laden jet flow modelling.
For steady particle tracking, there is an option of specifying step length factor/length scale to specify the time step that will be used for Lagrangian particle equation solutions.
However, when switching on the unsteady particle tracking, I can see particle time step size and number of time step options open, along with the step length factor/length scale options.
q1. What I understand is the number of time steps would specify the number of steps in which the particle equation will be solved (or the particle will advance in the flow) before the particle tracking is paused and flow calculations are done (for unsteady flow). next the particle calculations will be done integrating the updated flow info. is this correct?
q2. if the particle time step is already there, what is the role of the length scale factor? do we need to worry about the length scale factor if we have specifier the particle time step?
Kuntalika is offline   Reply With Quote
fluent, fluent multiphase model, fluent-dpm
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
DPM particle tracking "flow time step size" and " particle time step size" monali2015m FLUENT 0 February 26, 2022 17:37
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
